Good day ...
I need some information about technical data of this car :
Opel Insignia A, year 2011, engine 1.8i A18XER, ecu Delco E83 ...
car hasn't power, engine works normal but performace was bad...
Randomly generates P0101 error (i see that MAP and MAF was new original - checked diagnostics blocks - reads ok), there wasnt any air leaks ... checked via smoke generator
I need some info because only one thing i found in this car is injectors voltage
there is only 8V maximum (power is 12V on Gnd in open time is near 2.7-2.8V) im not sure - hasnt any car to compare but it is incorrect value ...
on 8V injectors works, car start but dose of fuel are very small
Ecu has good GND (<0.5ohm) for switching...
Can sb confirm injectors voltage ... i suppose ECU was damaged ...
