63
Thanks Given: 205
Thanks Received: 504 (224 Posts)
755
209
Can anyone help me with getting CAL and XML files for Opel Insignia ?
W0LGT5ES1E1076503
I usually got those from online SPS, but right now it's locked behind SERMI access in EU, and I'm still in the process of registration. So if anyone can get CAL and XML for BCM and IPC modules I would be gratefull
63
Thanks Given: 205
755
209
I've got calibration files already, but have a problem with editing them.
I need to remove AFL fault from dash, it's semi virtual, 8 inch display dashboard. Customer changed xenon converter as original one gave up. Of course chinesse ones don't support LIN communication there was dipped beam warning as well as adaptive lightning warning.
I turned off dipped beam error through xml file and I was able to disable adaptive lightning text warning. I had to modify one of the cal files. But I have a problem with a little adaptive light icon in upper right corner of the screen.
I was able to disable all other icons through IPC cal files, but whatever I do, it's still showing up. I tried to modify BCM files as well, but either I missed the byte for this or it's not in BCM either.
Anyone can help, point in the right direction or maybe modify correct cal file for me ?
