  • 18 Vote(s) - 2.72 Average
Is scn server under maintenance?
Hello guys.
Just want to check if the server is going under maintenance?
I am having some error.
Xdos 05/16 (last scn coding was done last month)
[attachment=157839]
Thanks given by: naseem__amg
xdos is old. use 09/2016 or 12/2016
(12-07-2016, 11:06 AM)crez Wrote: xdos is old. use 09/2016 or 12/2016
But the error message for old xdos shouldnt be vpo something?
Thanks given by: daxxer
I have the exact same problem and have been trying for the last 3 days and originally thought the system was down, but now think there might be a issue with blocked accounts ?
anyone having this trouble ?
(12-07-2016, 08:55 AM)alexjx Wrote: Hello guys.
(12-09-2016, 05:25 PM)juzzac Wrote: Hi,
Hello there.
Just checked with another member, we have the same problem with the same. Region username. So i guess its the username region problem.
Hello there.
if you use chinese account you must open port on your router or use VPN China it will work
Thanks given by: juzzac , alexjx , taisuke-san
Hello there.
Hi, do u mean that i need to make my connection behind vpn which has a china ip?
(12-09-2016, 06:37 PM)alexjx Wrote: Hi, do u mean that i need to make my connection behind vpn which has a china ip?
check here
Code:
http://mhhauto.com/Thread-FIX-SCN-Coding-Problem
Thanks given by: bawarek , alexjx
Dear Friends,
I heard...
Daimler saver had deep issue this week. 533
