KT200 II from experience
Hello to everyone,
I'm thinking about buying the KT200 II and would like to hear some feedback from people who have experience with it. I would mostly work on Mercedes cars (about 70%) and around 30% on VAG,BMW.
I fully understand that the best options for this type of work are Flex and Autotuner, but at the moment they are a bit too expensive for me. I already have KESS V2, and it works perfectly for Mercedes up to 2010, but I need something better for newer Mercedes models. Also i would like to know is there some additional,annual sub, and what is advantage of KT200 Plus.
Thank you all in advance!
Have a nice weekend!
I have it, it does job great, for older ecu's use kess v2 and for newer use kt200II , cant complain really. Autotuner is next on my buy list !
If I helped, give thanks + rep
hi
i recommend you another tools more cheap and more reliable first , like pcmflash and amt bst tool, when you foud ecus that cant do, then buy kt200
regards
for experimental & educational purposes ONLY ...
Thanks given by: gabi2013
(12-13-2025, 11:57 PM)NeoDJW Wrote: I have it, it does job great, for older ecu's use kess v2 and for newer use kt200II , cant complain really. Autotuner is next on my buy list !
Thank's for answer. AT soon for sure!
(12-14-2025, 08:37 AM)srzar Wrote: hi
regards
Thank's a lot on infos. I looked at pcm,but don't get it with all that modules. It goes a little bit pricey when you purches few modules that is neccesery to cover mercedes. Or I don't get it right.
I think you should also need a VVDI MB.
If I can help you, don't forget to Thank  Tup  me and leave a Reputation .   Drive
Buy genuine tools if you are working on customers cars... Alientech Kess3 is good.
//Chiptuning//Immo//EGR-DPF//Airbag//
Help other and other help you........maybe
Thanks given by: PAWELL GARAGE
(12-14-2025, 01:05 PM)Manhbuiduc Wrote: I think you should also need a VVDI MB.
You think it's better then CGDI?
(12-14-2025, 01:45 PM)Willinickersen Wrote: Buy genuine tools if you are working on customers cars... Alientech Kess3 is good.
I understand totally what are you saying,but now at this moment it's too much for me to give that amount of money. In your's opinion,kess3 is better then at or flex?
I'm also using the FC200 for copying Benz and BMW ECUs. It's slightly cheaper than the KT200, but it has an annual maintenance fee.
06-11-2026, 12:53 AM
Opel
06-05-2026, 08:51 AM
