KT200ii and edc15 ecus full system
hi
i´m trying to read on full system edc15c7 from fiat ducato with kt200ii , but only can do id correctly
when i try to read flash or eeprom allways fail
i put 120 ohm resistors on three wires from multicolor cable and check connections lot of times but no success
is there a trick or special procedure to make it works?
also have problems with more edc15 ecus on full system , only id but cant read
any help be apreciated
regards
for experimental & educational purposes ONLY ...
