  • 19 Vote(s) - 3 Average
KTAG HELP!!!!
i try install Trasdata but fail and my Ktag dont work.
Need Solution
[attachment=138999]
[attachment=139000]
(07-30-2016, 09:38 PM)bersch8688 Wrote: Hi,
Need Solution
First you must flash your device with correct file then you can convert it to trasdata
Tunefiles,Remapping,Egr/Dpf/Lambda,Flaps
Skype:Mazolla77
Thanks given by: bawarek
[quote='bersch8688' pid='748418' dateline='1469896728']
Need Solution
Flash back proper .EPT file and use v2.08 to bring it back to life (done several times myself). search forum also.
(07-31-2016, 03:57 AM)Bill Jefferson Wrote: [quote='bersch8688' pid='748418' dateline='1469896728']
Need Solution
changing .ept is for usb driver mate...but this tool as you can see is recognised by usb...it show you the fw version and serial number...that means ept is ok done for ktag...problem is no client number...that means sdcard fuxed...need new sdcard 2or4 gb and remake update with ksuite with update folder full wit families...after that change ept to trasdata and job ok doneBig Grin
Have anyone update files for ktag?
How to do?
(08-01-2016, 11:50 AM)bersch8688 Wrote: Have anyone update files for ktag?
How to do?
your problem now is solved...Kolo
Thanks given by: bersch8688 , Bill Jefferson , bawarek
Big Thanks on rofagaras
He solved my problem in few minutes
Thanks given by: rofagaras
How to do?
lol what just happened here???Itwasntme
Work hard
Play harder
05-30-2020, 06:56 AM
05-22-2020, 03:53 PM
05-10-2020, 07:13 PM
05-09-2020, 12:59 PM
