  • 6 Vote(s) - 3 Average
Kess token reset problem
Firmware update ok but when ecu tuner software start to reset the token it show tool not connected when i load the tokens, any help?
change sd card...
Thanks given by: Robert AMG
(09-09-2017, 09:06 PM)Robert AMG Wrote: Firmware update ok but when ecu tuner software start to reset the token it show tool not connected when i load the tokens, any help?
Contact PM i will help you.
(09-10-2017, 02:20 AM)ninolino Wrote: change sd card...
I did new one but same problem.
Which Kess do you have?
SN?
If This Helped You Rep + Thanks
Problem solved it was something wrong in the .ept eeprom, it opens fine in ksuite but not in the ecutuner token reset software.
01-21-2020, 07:00 PM
01-13-2020, 08:05 PM
10-09-2019, 02:22 AM
09-24-2019, 01:39 AM
