  • 15 Vote(s) - 3.07 Average
LWR FAULT 9002 and 9003 S211
Hello Friends
I have a problem and although I have the second pair of headlights now installed and also a new SAM Front and LWR control unit under the passenger seat . I have problem that I always current error 9002 and 9003 it, got in LWR controller . No communication with LWR controller left and right to what is the reason? the coding does everywhere and lights to which it can not be as it is now already the second yes . Please help me , I despair slowly . The headlamp leveling does not currently work . I can drive anything . There sit a S211 320CDI with Airmatik Year 2004
thanks denis
(07-27-2015, 05:12 PM)v8denis Wrote: Hello Friends
thanks denis
Hi I'm having the same error 9003 and the list is off.
how did you solve it?
thanks denis
Hello dudes.
Did you find the solution.
Try this.
Unplug one light LWR Plug (with 3 wires). If now the other light starts to work and communicate then probably the mechanical coding is wrong.
under the lights there are the LWR control units. If you take the unit away from light you see the two pin plug. If they are in the same side then LWR is fool. It sees 2 one side lights. It can be moved with a small screwdriver to other side.
Hi all,
Problem solved.
Replace Xenon Hella 5DV 008 290 00 (A0028202326)
Rukako
thanks denis
Hello dudes.
Try this.
Ok
But strange. This A0028202326 is only to light the xenon bulb and has nothing to do with LWR.
Best Wishies
Rotiratas
(12-23-2016, 07:28 PM)rukako Wrote: Hi all,
Problem solved.
Rukako
thanks denis
Hello dudes.
Try this.
