VIN: WVWZZZAUZHW376225 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHW376225 Mileage: 172859km-107409miles
01-Engine -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 60937000005267
Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 78A9E8FD6250B51A37B-802C
13 Faults Found
0143 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[valve calibrating data missing]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
0195 - Control module not coded
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
0338 - ABS/ESP Control Module
[inlet valve calibration data missing]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
8286 - Databus
U1123 00 [137] - Received Error Message
[FCAN: MO_Timeout_ESP signal is invalid]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:42
8299 - Databus
U1121 00 [009] - Missing Message
[FCAN: Anhaenger_01_alt veraltet bit is set]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:42
8306 - Databus
U1122 00 [137] - Implausible Message
[FCAN: Unplausible VIN number]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:47
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:25
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
32951 - Control Module for Electronic Parking Brake
C10E2 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 CD HW: 5Q0 937 084 CD
Component: BCM MQBAB B H34 0236
Serial number: 01001710800135 Dataset Number: V03935258XQ 0001
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7CA1F4ED5668993A533-8028
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A
Component: WWS 170320 043 0551
Serial number: 170410185044
Coding: 0E4DDD
Humidity sensor: interior:
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 71850549
2 Faults Found
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:27
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 13.3 V
Outside temperature: 25.0 °C
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:27
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 13.3 V
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels:* Redir Fail!
Part No SW: 5Q0 953 507 GB HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 21041704220668
Coding: 0600
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_VW37.rod
No fault code found.
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 B HW: 5G1 920 741 B
Component: KOMBI 202 9630
Coding: 07A52A002380000801082A001400000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 2615F685F864F3EA557-8072
2 Faults Found
16776967 - Databus
[EPB_02 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:53
16776973 - Databus
[RKA_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:53
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 3Q0 907 530 A HW: 3Q0 907 530 A
Component: GW MQB Low 416 4286
Revision: -------- Serial number: 0006234854 Dataset Number: V03935252FW 0001
Coding: 030000045F086800FA000248080F00010001050000000000000000000000
GVL: 01503C0000000000400C00000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013020
ROD: EV_GatewNF_VW37.rod
VCID: 2D0709A9DD92C0B294D-8078
Generator:
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 7376233604
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 080417ED740158 Dataset Number: V03935257JP 0001
Coding: 003003208000040000001000
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 41DF4519710A34D2405-8014
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000014390299
Coding: 110000
1 Fault Found
589827 - Window Regulator; Rear Driver Side
B131F 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:50:20
Address 44: Steering Assist
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 080417ED804144 Dataset Number: V03935257JW 0001
Coding: 003001208000040000801000
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 40D9401D7A003DDA4FB-8014
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000014378742
Coding: 090000
1 Fault Found
589843 - Window Regulator; Front Passenger Side
B1320 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:50:20
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 5G6 035 869 HW: 5G6 035 869
Component: MU-E--ER 611 8190
Serial number: 20011700021498 Dataset Number: V03935258X 0001
Coding: 027310003C00000041110001000002001F0000C40000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001039
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 71BFD5D9012AE452F05-8024
3 Faults Found
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:25
Voltage terminal 30: 12.6 V
7175 - Unlicensed Version. Not all DTCs
U1111 00 [009] - will be decoded.
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:51
Voltage terminal 30: 13.3 V
BAP-BAP_Function_ID: 00
7206 - Unlicensed Version. Not all DTCs
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:51
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.2V)-----------
Saturday,13,June,2026,13:55:28:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
13 Faults Found
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
U1013 00 [137] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
8286 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:42
8299 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:42
8306 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:47
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:24
Cannot be reached
Coding: 0E4DDD
2 Faults Found
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:27
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 13.3 V
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:27
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 13.3 V
Address 15: Airbags
Cannot be reached
Coding: 0600
2 Faults Found
16776967 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:53
16776973 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:22:53
Generator:
Coding: 110000
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:50:20
Cannot be reached
Coding: 090000
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:50:20
3 Faults Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:33:25
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:51
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 172859 km
Date: 2026.06.12
Time: 16:21:51
www.Ross-Tech.com
