Hey guys. This MAF is killing me. Check video.
https://imgur.com/gallery/Zu8QH0Y
Pin1- ignition voltage
Pin2-manifold absolute pressure sensor low reference. This wrong in Opel tis. This is ground
Pin3- intake air temperature sensor signal
Pin4-mass air flow sensor signal
Pin5-mass air flow sensor low reference
Now you can see from the video the reading I get on pin 4 at idle.
Now I checked voltage with connector disconnected and pin 4 is 5.1v pin 5 also 5.1v
I have ground and voltage. Temperature sensor reads well. And I have no codes.
