107-15-2019, 10:22 AM (This post was last modified: 07-15-2019, 01:51 PM by HestonDiag.)
I would be very grateful if anyone can please remove these DTC from this ECU:
P20DC-002 B37 (Accelerator pedal sensor) : Signal 1 / Chort circuit to ground / Potentiometer below minimum value or defective (P0122)
P20DE-002 B37 (Accelerator pedal sensor) : Signal 2 / Chort circuit to ground / Potentiometer below minimum value or defective (P0222)
P2026-001 Y58/1 (Purge Control Valve) Short circuit to UB / Switchover valve permanently closed (P0445)
P2026-002 Y58/1 (Purge Control Valve) Short circuit to ground / Switchover valve permanently open (P0445)
P2026-004 Y58/1 (Purge Control Valve) Open circuit / Switchover valve permanently closed (P0444)
(07-15-2019, 10:22 AM)HestonDiag Wrote: I would be very grateful if anyone can please remove these DTC from this ECU:
attach ecu read pls
Chiptuning DynoTested File services - DPF/EGR/DTC Exc PCR2.1 Full Clone - Edc17 Full clone
P20DC-002 B37 (Accelerator pedal sensor) : Signal 1 / Short circuit to ground / Potentiometer below minimum value or defective (P0122)
P20DE-002 B37 (Accelerator pedal sensor) : Signal 2 / Short circuit to ground / Potentiometer below minimum value or defective (P0222)
Generic P code DTC using Launch EOBD (and some I had to look up on internet because I could not make all DTC happen again today.)
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction - Read with Launch (P20DC-001/P0122 according to DAS)
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input - I could not make this fault happen today so I have looked up fault code
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction - I could not make this fault happen today so I have looked up fault code
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input - I could not make this fault happen today so I have looked up fault code
P0443 Evaporative Emission Control System Purge Control Valve Circuit - Read with Launch (P2026-001/P0445 according to DAS)
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open - I could not make this fault happen today so I have looked up fault code
P0445 Evaporative Emission Control System Purge Control Valve Circuit Short - I could not make this fault happen today so I have looked up fault code
(07-15-2019, 08:10 PM)HestonDiag Wrote: DTC from Star Diagnostic/DAS:
On file i find only this active:
P0120
P0220
P0443
Pls check
Unfortunately today I tried many times to make open circuit/short circuit to try and bring back more DTC's, but only DTC I could make happen was P20DC-001/P2026-001 (DAS fault codes).
Can you please remove P0120/P0220/P0443 for me, and hopefully this will be enough.
(07-15-2019, 09:32 PM)HestonDiag Wrote: Thank you for looking at my file.
P0120 OFF
P0220 OFF
P0443 OFF
