72
Thanks Given: 706
Thanks Received: 583 (231 Posts)
336
02-06-2017, 11:52 PM
(This post was last modified: 02-06-2017, 11:53 PM by art_arev .)
Green goes to pin7 of the combination switch. It is circuit P
Art
13
Thanks Given: 164
Thanks Received: 92 (49 Posts)
321
62
02-07-2017, 08:54 AM
(This post was last modified: 02-07-2017, 08:57 AM by mastero .)
Guys sorry but what is circuit P for ?
The vehicle in question is not starting and i am not getting any volts on that wire.
can someone please put light on what that green wire is for and where does it goes to ?
thanx a million
72
Thanks Given: 706
336
Didn't you read post#4? It is for the combination switch - Turn signal/hazard warning system.
Tell us the symptoms. What exactly is happening. Is the engine cranking? What codes do you have?
Art
13
Thanks Given: 164
321
62
The engine cranks but does not fire
Getting no fault codes.... on star.
While shaking the ignition switch wire by hand it fires and the dies again.
then sometime it does not fire at all.
Camshaft crankshaft sensor changed.
any ideas?
72
Thanks Given: 706
336
02-07-2017, 09:43 AM
(This post was last modified: 02-07-2017, 09:45 AM by art_arev .)
You might have a fuel delivery issue. Get a fuel pressure gauge & check the pressure at the schrader valve.
Have you changed the Cam sensor or Crank sensor? Is it/are they proper Bosch?
Thumbnail(s)
Art
13
Thanks Given: 164
321
62
fuel delivery is fine cam and crank is fine.
The issue is there is no power going through the Green wire P30
can this issue not let the vehicle start ?
fuel is not the issue the coils are not firing.
all fuse ok ..... it feels like immobilizer is not letting the vehicle start.
but don't get start error on the kombi
