MMCodingWriter + MUT Coding
MMCodingWriter - https://www.dropbox.com/s/50uj0q1yeaxf65...1.zip?dl=0
MUT Coding - http://tradesyndicate.org/MUT%20Coding%20Mitsubishi.zip
https://forum.kolyandex.su/
MUT-III J2534 Driver - https://forum.kolyandex.su/viewforum.php?f=14
Thanks for the upload but how does the driver work? I downloaded it and it seems to be locked to a HWID.
How can I download MUT-III J2534 Driver ?
Thanks given by: kentool
J2534 driver cost per License key about 150-200 USD per license.
Microcontroller Program & Developer.
Programmer Tooling for support.
(01-14-2020, 11:42 AM)mcusys Wrote: J2534 driver cost per License key about 150-200 USD per license.
OS support
VCI-Lite emulator - Win 7+
Other versions - Win XP+
Supported adapters:
Tactrix OpenPort 2.0 (original) — full support (chinese clones also working, but no warranties)
ScanDoc Compact (J2534) — full support
Scanmatik 2/2 Pro — full support
Toyota Mini-VCI — support onlu CAN vehicles with limitations (can't write long ECU coding)
Other J2534 adapters — if it fully supports J2534 - Full CAN vehicles support, partially support for k-line vehicles. Not work with ECUs, where used pin 1 in OBD
Versions:
1. Pass-Thru without security keys
Without the ability to record and perform any operations where you need to exchange security keys (change pins, write coding (except for custom), flashing keys, etc.). You can watch the data, perform simple calibrations (sas, RLS). No k-line, no reprogramming.
2. Pass-Thru with security keys - as 1, but no limitations. No k-line, no reprogramming.
3. Emulator of Lite adapter
Full, without limitaions.
— CAN
— k-line (OBD, ISO-MMC, KWP) only on pin 7 (look schematics diagram). ~ before 2000 year vehicles not working.
— CAN bus ECUs reprogramming. Vehicles list
Which version do i need?
Exhaust sensors graph (Lancer X/ASX/Outlander 3/XL) - 1
Read and erase errors (DTC) (Lancer X/ASX/Outlander 3/XL) — https://vk.com/mmcodingwriter or 1.
Calibration of camera/radar (Outlander 3) — 2.
Fill AYC/ACD (Evo X) — 2.
Register new immo keys — CAN bus — 2, k-line — 3.
Edit engine/ETACS coding — https://vk.com/mmcodingwriter or 2.
Update ABS/ETACS/Engine/other ECU firmware — 3.
Old vehicles diagnostics (Lancer 9 / Pajero 3 / Outlander 1/ Lancer Cedia) — 3.
Replace used Immo — 3.
Price:
1. 20 USD
2. 60 USD
3. 150 USD
Add-on for Nippon Seiki meters with MB91F223 CPU (read/write EEPROM, only for version 3) - 10 USD
In backup we trust.
Top
04-24-2020, 08:52 AM
Misubshi
03-26-2019, 10:19 PM
Misubshi
10-01-2017, 06:49 PM
Misubshi
08-27-2017, 07:35 PM
Misubshi
05-22-2017, 09:17 PM
Users browsing this thread: 3 Guest(s)
