  • 1 Vote(s) - 4 Average
Mazda BT50 SID208 on Ford Ranger
Hi all,
We took PCM, BCM and Ignition from a Mazda BT50 3.2 Manual to a Ford Ranger 3.2 Manual, everything works fine but dash odometer is not showing mileage information.
Does anyone know how to solve ?
Thank you
hi .you need to do installation and program with ids in some cases it is necessary to do as was built data
(06-13-2018, 06:41 PM)tallerjarquin Wrote: hi .you need to do installation and program with ids in some cases it is necessary to do as was built data
Edit: Will check thanks
(06-13-2018, 07:45 AM)FIT_ECU_Tuning Wrote: Hi all,
Thank you
Need Parameter reset, go to PATS key and Parameter reset. But need BCM and PCM incode outcode ,I think no need to replace
Ford Ford Transit SID208 checksum Alexzoz 0 88 09-16-2018, 04:25 AM
Last Post: Alexzoz
Ford bt50 (ranger) pin code dagomnet 1 111 09-14-2018, 05:13 AM
Last Post: kostasm
  need adblue off for ford ranger 3.2 ecu seimens sid209 cyber30 1 70 09-10-2018, 11:43 PM
Last Post: Mirnel
  ford ranger 24c16 craciunaero 1 82 08-28-2018, 01:27 PM
Last Post: clusters
  Ford Ranger Mileage 2013 24C16 AutoLectricZA 4 110 08-07-2018, 05:39 AM
Last Post: clusters
