The car was constantly smoking, both at idle and under throttle. The turbocharger was replaced, and after that it stopped smoking.
However, the oil level in the crankcase increased. I’m wondering whether the engine was performing DPF regenerations, or if it’s possible that faulty injector sealing washers caused diesel fuel to leak into the oil, increasing the oil level.
About 30 minutes ago, the engine seized — most likely the crankshaft bearings were washed out, which led to the seizure.
