  • 17 Vote(s) - 3.59 Average
Mercedes 204 Communication error (1.58642.0)
I'm on Windows 7 with Xentry OpenShell 09/2016 installed. I tried connecting my SD Connect C4 to a 2008 Mercedes C300 (204) and it gives me this error.
My SD Connect is on the latest firmware.
Communication error (1.58642.0) :
com.teradyne.ds.gradex.asam3d.Asam3dHWException: Error details: MCDError: <Undefined> (0xe512) VendorCode: [0]   at intern/prepareInterface%20-%20Task/NODE5   in file:/C:/Program%20Files%20(x86)/Mercedes-Benz/Xentry/Kontexte/Allgemeine_Ablaeufe/Fahrzeug-Kommunikation/Asam.gmf
I used my friend's laptop who has 05/2015 installed and I was able to use my SD Connect C4 on it fine.
I uninstalled and reinstalled Xentry. Applied the Blacklist patch, 2221-45 fix, DAS fix and startkey fix.
Does anyone have any idea why I get this error?
For Sale:
CDA 6 Installation, FCA Flash File Downloader, JSON Error Fix
Nissan IP Characteristics CVT Transmission CSV File Service
Module Cloning Services - USA Only
Honda i-HDS diagnostic software
What else do you have installed?
Becouse, if you installed only XDOS and without errors.. the problem its on other part of your installation.
BR
If you like it please click on REPUTATION and THANKS
I think Xentry itself is corrupted. I just tried it on a 2014 ML and it gives me the same error.
For Sale:
Update: installed Xentry 07/2016 and it works. The version of 09/2016 may have been corrupted when I downloaded it. It's weird. Xentry wouldn't work but DAS works.
For Sale:
This its a "driver" problem under xentry..
What else you have installed????
(10-20-2016, 11:56 AM)cocoh Wrote: This its a "driver" problem under xentry..
I have to rephrase what I said earlier. Xentry 07/2016 worked on a fresh OS install. When I installed it on my laptop with my other software, it gave me a communication error again.
On the laptop I have
ODIS-S
ISTA-D and ISTA-P
Tech2win
JLR SDD
Nissan Consult 3+
All Data
Mitchell
Hyundai GDS
Xentry/DAS
For Sale:
Driver issue since you have a whole bunch of other software running as well and they all come with their own drivers. Some might be the same but different versions or revisions which could cause this. MB doesn't like to share their hard drive space. It's the Über-Race of all diagnostics software.
(12-25-2016, 02:04 PM)Mackhack Wrote: Driver issue since you have a whole bunch of other software running as well and they all come with their own drivers. Some might be the same but different versions or revisions which could cause this. MB doesn't like to share their hard drive space. It's the Über-Race of all diagnostics software.
Should've mentioned, but I resolved this.
I made multiple partitions with a few software in each. MB works fine now.
Thank you.
For Sale:
