  • 34 Vote(s) - 2.53 Average
Mercedes-Benz COMAND APS NTG4 audio problem
Hi everyone,
I have trouble about sound of comand aps ntg4.
The problem is in the link
MIB 1/2/2Q_MHS2_MST2_PQ_ZR_PCM4.0/4.1_ RMC-2021, Newest Maps, All Activation, USA2EU,Harman,Delphi,Technisat,Preh.
Do you have Harman/Kardon?
Thanks given by: naseem__amg
(07-30-2016, 02:20 PM)Aless91 Wrote: Do you have Harman/Kardon?
No it's not Harman/Kardon
This is the unit
he means if car is equiped by external sound system or if internal amp in comand is used
Your vin should be WDD2040081A259355 if yes, you do not have external amp, so mosh likely your internal amp is broken.
(07-30-2016, 10:58 PM)Aless91 Wrote: Your vin should be WDD2040081A259355 if yes, you do not have external amp, so mosh likely your internal amp is broken.
Hi
Thank's for your response
This radio work with internal amplifier and used TDA7563,I already replaced with a new one.
I installed the radio, began to work perfectly but when I start the car or the radio off and on again the same thing ,no sound as on video I posted in first post.
This is an interesting defect, I had not had the opportunity to face with something like this before.
So I would like to someone who had experience with something like this to share with us the solution.
I wish all the best!
Regards
KNaudio
Hi
Regards
KNaudio
Do you have latest software in COMAND (head unit software, not navigation one) and correct coding as well?
Hi
Regards
KNaudio
If the radio is cutting off and on only when the engine is running maybe your system voltage is too HIGH!! Is the alternator malfunctioning?
Hi friends ,
i have solution for this problem , but it is not free.
Please PM for details.
Thanks given by: tuninggas90
Yesterday, 03:30 PM
06-10-2021, 03:08 PM
06-09-2021, 12:06 AM
06-08-2021, 06:55 PM
