I had a W220 with key lost.
Can i get any advice to make a new key for this ?
Thanks in advance.
Thanks in advance.
(11-23-2014, 08:25 PM)careforever Wrote: I had a W220 with key lost.
Thanks in advance.
(11-23-2014, 09:10 PM)careforever Wrote: Hi kostasics,
need to remove ESM and ECU as well ?
whats the tool you recommend for doing this read and write function ?
(11-23-2014, 09:56 PM)careforever Wrote: Well, i plan to buy AK500+ and a new blank NEC key. So am i ready to go ?
Because i saw a video from youtube it needs to remove 3 item : EIS+ESM+ECU
i guess he is using AK500(without "+") and without SKC calculator am i right ?
(11-23-2014, 10:10 PM)kostasics Wrote:(11-23-2014, 09:56 PM)careforever Wrote: Well, i plan to buy AK500+ and a new blank NEC key. So am i ready to go ?
Nop , you need only the read of eis and ONLY to read not write .
After that you generate a key write in ak500+ and you are ready .
Note to order key that the ak500+ can write and the other the frequency of the key . There is 315mh and 433 .
Good luck !!
(11-23-2014, 10:20 PM)careforever Wrote:(11-23-2014, 10:10 PM)kostasics Wrote:(11-23-2014, 09:56 PM)careforever Wrote: Well, i plan to buy AK500+ and a new blank NEC key. So am i ready to go ?
Good luck !!
How am i going to know that im using 315 or 433mhz (this is confusing)?
Means after i got my ak500+ i will read the EIS dump and calculate the SKC then write a new key right ?
