Hello everyone. I am back with a new issue. Finally managed to get the central locking issue solved
This gives me the time to look into other issues with this car. There is a problem with the idling. It starts with a little difficulty and then the idling is very erratic playing around between 1000 rpm to zero, even stalling if the accelerator pedal is not kept pressed slightly. When the temperature gets to about 65 degrees C, it suddenly goes to about 800 to 900 RPM and sits there perfectly. Totally stable! Someone has advised me to replace the actuator but since I have found that this is very expensive, I have opted for further advise from my friends here before I haste into an expensive repair that may not solve the problem I have. Please help!
