Thanks Given: 314
Thanks Received: 44 (21 Posts)
174
41
Hi, i have the P2602 on a mercedes W211 220cdi
P2602 "The voltage supply of the valves is faulty"
i change the plate conductor in gearbox but dtc still present
any idea ? EGS maybe ?
thank's
677
Thanks Given: 229
Thanks Received: 1429 (407 Posts)
1,143
202
Try to disconnect MAF and EGR
99
Thanks Given: 100
Thanks Received: 384 (239 Posts)
625
31
locate the TCU, and see if there's oil in it.open and check if the capacitor is broken.
transmission harness is wicking fluid to the TCU.and after disconect m55 airflaps
motor''
ECU-REPAIR-KEYS-IMMO-ABRITES FULL MERCEDES-ALFA-PSA GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
Every days a schoolday
383
Thanks Given: 922
Thanks Received: 1396 (515 Posts)
1,230
169
If the fault was cleared and come back again immediately after start the car, then change the battery.
