Thanks Given: 203
Thanks Received: 80 (53 Posts)
1,215
586
06-28-2019, 02:44 AM
Hi, i have here a sprinter with a edc17cp10, my file is a dpf and agr off file but dosen`t work, errror message pressure sensor.
Can someone check it and can say what`s wrong with that ?
82
Thanks Given: 1828
Thanks Received: 736 (385 Posts)
885
What pressure ??? Exhaust Back pressure ???
This engine will not work without back pressure sensor , because turbo actuator logic uses back pressure as feedback to calculate VGT position. And boost pressure error after delete is direct result of missing,bad,or clogged back pressure sensor. We found it by our-self and did educated tuner on this issue (for some reason most tuner do not know this).
Thanks Given: 203
1,215
586
the b28/20 dpf pressure sensor.
Sensor is inside and work (without goes in secure mode 2000 rpm)
