Mercedes W221 S63 AMG Terminal 87M1
I have a Mercedes W221 S63 AMG with the M156 engine. The car came to me with fuse No. 21 in the engine bay fuse box blown.
I’m trying to identify exactly what this fuse supplies, but I haven’t been able to find a clear component list for the circuit.
According to the diagram, fuse 21 appears to be related to Terminal 87M1, but what I specifically need help with is identifying every component powered downstream of this fuse and understanding where the circuit branches after the fuse.
In other words, I’m trying to find out what can actually cause fuse 21 to blow — for example ignition coils, camshaft sensors, O2 sensors, injectors, ECU-related feeds, starter-related circuits, cooling fan, front SAM/BCM, or any other engine-management components.
I tried tracing the circuit in StarFinder and attached a screenshot, but I’m having trouble following the 87M1 distribution and understanding what is connected after fuse 21.
If anyone can explain the diagram or provide the downstream component list / wiring path from fuse 21, that would be exactly what I need.
Thanks!
Hallo, as the diagram showing it's related to the starter, can try check with Xentry / DAS disconnect the fuse check engine start make short test and see the faults appiers related to this fuse
Mit freundlichen Grüßen | Best Regards,
Specialist for Mercedes PKW / LKW
Modifications / Diagnosing / Programming
Hello, I tried removing the fuse. There are no DTCs, but the starter does not crank.
The fuse originally blew while the car was being driven, and the engine shut off immediately.
According to WIS, fuse 21 for M156 engine is listed as 2.5 RDBU (12 or 14 AWG Red/Blue) and Circuit 87 M1i connector sleeve (Z7/38). Z7/38 is one of the main engine wiring harnesses supplying power to IGN coils, fuel injectors, camshaft adjuster solenoids, etc. Could be a short to GND on any one.
The fact that you're not getting any DTC suggests the main engine ECU is not even booting and getting no power to begin and there may be short to ground in harness somewhere upstream of coils, injectors, cam adj. solenoids, etc.. I would disconnect coils, injectors and cam adjuster solenoids and see if fuse 21 blows to confirm. If the fuse does not blow, then look for short to gnd on coils, injectors, or cam adj. solenoids. Otherwise, need to dig down in the wiring diagrams and see what other components are routed on Z7/38 sleeve and/or find short to GND in harness itself.
(10-01-2026, 08:06 PM)SpiderMan713 Wrote: According to WIS, fuse 21 for M156 engine is listed as 2.5 RDBU (12 or 14 AWG Red/Blue) and Circuit 87 M1i connector sleeve (Z7/38).  Z7/38 is one of the main engine wiring harnesses supplying power to IGN coils, fuel injectors, camshaft adjuster solenoids, etc.  Could be a short to GND on any one.
Yes, exactly — this is the kind of help I’m looking for.
What I need is someone who can actually trace Circuit 87 M1i / Z7/38 through WIS or StarFinder and identify every branch and component supplied by fuse 21 on the W221 S63 M156.
I have already tried following the diagrams myself, but I couldn’t trace the circuit completely and I don’t want to start disconnecting components blindly.
I’m willing to pay for the time required to research it properly. What I’m looking for is a precise answer showing:
- every component supplied through fuse 21 / Z7/38
- where Z7/38 branches into the individual circuits
- relevant connector numbers and pin numbers
- intermediate connectors or splice points
- whether the ME/DME itself receives power directly or indirectly through this circuit
- which branch would explain both the blown fuse while driving and the current no-crank / no-DTC condition
Basically, I want to work through the circuit systematically with a multimeter and isolate the short branch by branch.
If someone can trace the complete circuit in WIS/StarFinder and provide the exact wiring path, I’m happy to pay for that information.
I attached what I was able to find.
.txt
M156 StarFinder T87 Diagrams.txt
54 bytes
install offline wis, you can find all you want.
DTS9.04.016
MB software
206223coding
M6+ Pro,C3
DS,Citroen,Peugeot Online
Lexus online//DST010
