Mercedes bad noises under car
Hi my Mercedes has some strange sounds behind when I give it a bit of gas heppends only when driving at low rmp give a bit gas and lot of vibration back of the car what can be the proglem mercedes w211 270cdi automatic
Is it same as this noise
https://youtu.be/-RJPg2axfcQ
If you have read a post by anyone on this forum and it helped
please leave thanks and reputation, the two buttons below it takes only 1 second
its especially important to new users to recieve and give Thanks James
Have you checked the driveshaft center support?
DO NOT PM me asking for help with files.
Post your questions in the forum, that is what it is here for.
(12-03-2018, 03:27 AM)clusters Wrote: Have you checked the driveshaft center support?
thank you I'll check it out
100% converter automatic transmission.
If you have xentry/das you can disable this function for a test drive .
And look if there is a different .
Or give tv if you have xentry/das I can help you
