  • 13 Vote(s) - 3 Average
Mercedes w211 automatic problem
Today l buy a mercedes E270cdi 2003 everything was fine l drive about a 100km and when l came on a hill the car does not change the gear when l prees full throttle is shifting when a drive now normaly its stay on 1s gear, and in manuel mode is not shift gears only when is in D and stuck in 1s gear l pull in + and shfit sometimnes
First check are any dtc.
l dont have dtc
How do we know about your problem if we don't even know what W211 you have...... there plenty of engines and at least 2 automatic transmissions , 722.6 and 722.9
Today l drive the car about 1h everythnig is oke .????
Did you accidentally hit the shifter to the left? it will cause the car to go into first gear and hold it until you accelerate to red line or move shifter to the right or put in park and back into drive..
Look at the display in the instrument cluster next to the odometer.. if it doesn't have a "D", then you have knocked the shifter over, or the shifter switch is bad and doing it by itself..
Big GrinDDD no when l drive to much is happen that
