Mersedes vito 166 2022 adblue problem
Hi guys! After replacing the SCR module on a Mercedes Vito W447 116 (2022), the following error codes remain in the engine control unit: P300839 and P30065Dcommunication with the AdBlue control unit has a functional malfunction.. There are no faults stored in the SCR control unit. The AdBlue level is displayed correctly on the instrument cluster.
Does the SCR module need to be coded/programmed?
Thank you.
(04-10-2026, 02:26 PM)dimansky Wrote: Hi guys! After replacing the SCR module on a Mercedes Vito W447 116 (2022), the following error codes remain in the engine control unit: P300839 and P30065Dcommunication with the AdBlue control unit has a functional malfunction.. There are no faults stored in the SCR control unit. The AdBlue level is displayed correctly on the instrument cluster.
Thank you.
Assuming the hardware is correct, you should at least check the software and the encoding.
Thanks given by: dimansky
Thank you.
It seems like online access is needed
Thank you.
1- why replacing done ??
2- Did U followed Xentry Module Replacing Steps ??
Services:
- MB SW
- MB Trucks
- Xentry Special SK
- Mod(EGR, SCR, DPF & Adblue OFF)
- EPC On/Off line (Cars,Trucks & Equip)
- AutoVEI, DIMSport, Jaltest,CD400
Thank you.
The old SCR block was faulty. Xentry is available, but I don’t know where to find the instructions.
Remove adblue shit, problem will be solved
//Chiptuning//Immo//EGR-DPF//Airbag//
Help other and other help you........maybe
Thanks given by: cocoh
(04-11-2026, 11:02 PM)Willinickersen Wrote: Remove adblue shit, problem will be solved
Can you do this only with DTS?
If you like it please click on REPUTATION and THANKS
06-08-2026, 06:15 PM
06-04-2026, 02:01 AM
06-04-2026, 12:55 AM
