  • 7 Vote(s) - 2.29 Average
Mitchell Heavy & Medium Truck Error
Im am suddenly getting an error with both these softwares that is not allowing me to use them at all. when opening the software i get a pop up with error:
"Unable to access host computer.
Please check your network connection or data path settings and try again."
When i try to open the options for systems, year/make/model, or tsbs and recalls i get the same pop up.
(05-30-2018, 06:55 PM)ddserv Wrote: Im am suddenly getting an error with both these softwares that is not allowing me to use them at all. when opening the software i get a pop up with error:
You have to uninstall it manual, selecting all files manual and yes to the warning, or do the same using revo uninstaller
Install and register using the floppy or code entry
Make sure the DVD is loaded prior of running MTR if you are mounting a ISO image, make sure its in correct drive
Did that, still get the same error.
07-20-2019, 11:23 PM
07-13-2019, 05:41 PM
07-05-2019, 12:14 AM
AA MAN
06-22-2019, 04:58 PM
