Mongoose jlr pro and globaltis v32 question for expert
Hello everyone, I have a question about globaltis v32 offline. I need to reprogram all the control units (ecu engine body and other ) of an opel corsa d 2008 Z12xep. As j2534 I have a mongoose pro jlr China version that I needed and worked very well in past for programming in jdd, and also for use with odis. I have installed globaltis v32 on vmware and it is recognized correctly. In your opinion, being a j2534, can it do sps programming of the control units?
(03-21-2025, 10:38 AM)Dronx81 Wrote: Hello everyone, I have a question about globaltis v32 offline. I need to reprogram all the control units (ecu engine body and other  ) of an opel corsa d 2008 Z12xep. As j2534 I have a mongoose pro jlr China version that I needed and worked very well in past for programming  in jdd, and also for use with odis. I have installed globaltis v32 on vmware and it is recognized correctly. In your opinion, being a j2534, can it do sps programming of the control units?
SPS yes it will work
Tech2win and TIS programming doubtful but you would need to try yourself.
Hi!
Can I use also openport 2.0 cable with global tis?
Or which cable you preferre?
Thank you
05-12-2026, 12:43 AM
Vauxhall
02-24-2026, 08:06 PM
