  • 16 Vote(s) - 3.5 Average
MultiEcuScan 3.6 version 4.2017
28
(04-29-2017, 03:07 AM)koyot Wrote: not work windows xp
Can you confirm if it will works with Windows XP?
Sent from my iPad using Tapatalk
Invalid License key!!!
Someone can tell me HDD serial so I can generate the right key?
Thanks!
(05-31-2017, 01:05 PM)relaxx82 Wrote: Working perfect. Thanks
Can you give me your HDD serial number to activate my copy of Multiecuscan?
You can find typing vol C: on command prompt.
If your versione is fully activated, I can try to do the same with my!
Thanks.
No one can help me?
Can anybody help me with this. I have posted the link below. I am on my phone and can t put it in .txt file. On a 2014 Fiat Ducato 2.3jtd 130 i can connect only on engine and ABS system. The rest it gives the error in the photo below. I have bluetooth v1.5 elm327
Code:
https://mega.nz/#!wVBHyAIY!0Lv_6_qihYlEbPAH02dHu-0fRyuEjVkHXpCqmaTQbbI
Diagnostics only.
(07-22-2017, 07:12 PM)AfXv237 Wrote: Can anybody help me with this. I have posted the link below. I am on my phone and can t put it in .txt file. On a 2014 Fiat Ducato 2.3jtd 130 i can connect only on engine and ABS system. The rest it gives the error in the photo below. I have bluetooth v1.5 elm327
Code:
can you help me to let work multiecuscan on my pc?
I need the bed serial number to try with a Lethem...
Hi guys can you suggest me right devices that works fully with k line and can system? Except cantiecar multiplexer as it is too expensive for the rarely job I do with fiat...
Thanksin advance
If You got the solution please report back and let others know, this is how forum works.
+Rep & Thanks Appreciated
Hi what interface do i need to work with euro 5 ducato with mjd8 ecu will the like elm work on these
new version
with patch + key in it Cheer2
No password without reputation and thank's
Thanks given by: batty
06-13-2026, 04:02 PM
