  • 24 Vote(s) - 2.63 Average
Multiecuscan 1.4 Patch
Step 1: Before multiecuscan 1.3 to install.
Step 2: Make the patch was then attached file.
Step 3: After Patch Install Multiecuscan 1.4
Rar Pass: By ircpoLice
Good Luck...
Multiecuscan 1.3 Patch.rar
707
2.02 MB
B E Ş İ K T A Ş K
Another Multiecuscan 1.4 Registered !!!
simply install !!!
Multiecuscan_1.4.rar
728
132 bytes
Info before you install Multiecuscan1.4 from post above make register clean .
copy this two red lines in texteditor or notepad and save it as multiecuscan.reg
Windows Registry Editor Version 5.00
[-HKEY_LOCAL_MACHINE\SOFTWARE\Multiecuscan]
klik on the ***.reg file you just made it and say yes to the box and register is ready for the new Multiecuscan
(maybe run as administrator depent on your UAC settings)
(05-10-2013, 10:19 AM)dnv_soft Wrote: Another Multiecuscan 1.4 Registered !!!
simply install !!!
it is the same than Debutant version
Thanks given by: dopsleutel13 , Debutant , ToMiBoY , perotok
Dont forget the credits goes to mr debutantTup
Hello on the other hand with the version 1.4 for 159 16v jtdm for the reset service(department) that always puts error cable while the version 1.3 works tres well
Check port and speed.
It is quite made other function(office) walks(works) except reset service(department) with the version 1.3 it is OK
thanks to ircpoLice..work with full activation MES 1.4Tup
DriveThanks? Reputation rating? Why not!
Ford
02-26-2020, 02:40 AM
Ford
02-18-2020, 10:40 AM
Chevrolet
01-03-2020, 10:50 PM
01-02-2020, 10:09 PM
Ford
12-22-2019, 09:55 PM
