  • 7 Vote(s) - 3 Average
NAVI in W205
Hello ppl,
I have a Mercedes-Benz C-Class (W205), but I dont have Navigation.
I bougth a used W205 without this option. Now, I would like to enable this option.
What I need? Hardware or Software Update?
Regards
EMiranda
(06-09-2018, 03:22 PM)tEaM Wrote: Hello ppl,
Regards
EMiranda
you can change the head unit and also need to add gps antenna connection. can use aftermarket antenna in these head units.
here to share and care!
Dont forget to rep+ and thanks!
Handshake
It depends, if you have code 522 no need for headunit change.
Many thanks!
But... how I check the code of my headunit?
... SA Code in EPC
simple its a screen with out edges bigger screen its ntg5
smaller screens mostly coming garmin
or just epc check your car datacard
or pm me vin
Mercedes BENZ CODING 223/254/214/206 STAR3 ECUS
MERCEDES BENZ CODING
JLR CODING AND PROGRAMING
Region Conversion & MAP PIN: NTG 4.5/4.7/5/5s1/5.5/6/7/GEN20x
Thanks given by: naseem__amg
According to my VIN (WDD2052371F242690), I have:
522 - AUDIO 20 RADIO NAVIGATION CAPABLE NTG5
What does that mean?
What do I need to have Navigation?
You need USB Slot with SD (A2058200126), GPS Antenna, Garmin SD card, than coding and done
(06-12-2018, 10:44 AM)sherwin1111 Wrote: You need USB Slot with SD (A2058200126), GPS Antenna, Garmin SD card, than coding and done
Thanks, @sherwin1111.
I can buy usb slot with SD, GPS antenna and Garmin SD card.
But the coding ... It will be difficult to get someone to do this in Portugal.
