NEED PIN CODE RCD510
Hy ,
i need pin code for VW RCD 510
3C8 035 195
VWZ1Z3I7904361
Blaupunkt
Thank you in advance
Read eeprom 95128
//Chiptuning//Immo//EGR-DPF//Airbag//
Help other and other help you........maybe
Thanks given by: mm04kk
ALSO NEED INFO IN MCU NEC
https://codecard.lt/index.php?act=viewPr...ductId=665
BEST TOOL FOR THIS TYPE CARRADIO
MANUAL FILE SERVICE WITHOUT PREPAID.
EVC RESELLER ALEXEJLAZ.
Hy thank you my friends. I have payd by a online service for the code. 1213 but my radio says wrong. I have bought this radio on scrapyard maybe someone has changed the mainboard so that the serial number on the cover is wrong . is there possibility to read serial number from eeprom?
Test in Car.
English its not my native language  whew If i helped you give me Thanks and Rep
i have tested always in car wrong
I have now readed the eeprom 95128 but i can not read the nec i tried with D70F33XX reader but always init error 1 i have used the diagramm on the picture and my pc comport . I have attached my dump from eeprom and pictures of my pcb mybe there is other connection method.
M95128.rar
12
2.39 KB
Com port direct ? or FTDI converter ? Try adjust com port settings. Dont forget connect radio +12v BUT do not turn ON !!!
Connect the unit to a PC via any adapter COM - Rx Tx (MAX232) or USB - Rx Tx (FT232, FT245 or others).
Button between the solder and the point Masoyein RESET.
Radio RxD - TxD adapter, the data from the PC to the radio.
Radio TxD - RxD adapter, the data from the radio to the PC.
Radio is connected to a 12 V, off.
Submit a 5 V via a 100 point on Om MODE
(or 12 V through resistor 12 kOm as shown).
By 1 sec. press RESET.
Run program NEC D70F33xx Reader.exe, select the port
Press INIT, then Read.
Thanks given by: Bob the builder , mm04kk
can someone pls reset my counter in the eeprom
Hy my friend now NEC reading was possible rx and tx was wrong point i have soldered them like the picture attached . Can someone provide me pls the code thank you in advance
M95128.rar
15
2.39 KB
nec D70F3356.rar
16
324.99 KB
KIA
06-05-2026, 05:16 PM
06-02-2026, 09:25 PM
Renult
05-30-2026, 05:39 PM
