didn't work on windows 10 64bit; I let it run for a while and it disabled/reenabled my adapter but never set my local ip; I just manually did it after getting ip from sdconnect toolkit
Greetings Sir!
Maybe this is Solution to my problem? Please send me working link for testing.
I have SDconnect installed on a Emulator which uses network Gateway 10.0.2.2
Which is connected to Router with Gateway 192.168.47.30 (Android Hot-Spot) or Router with 192.168.0.1 Basic Home Router)
The C4 is connected via "Wlan Workshop Mode" to one of the Routers. (192.168.47.21/192.168.0.93)
SDconnect on (WinXP)Emulator is connected via Emulated LAN card with IP 10.0.2.15
directly to Androids built in router, IP on the router is unknown but its around 192.168.47.xxx
or Via Androids Devices IP to Home basic router.
So to the Q:
Will this software be able see the C4 MUX if yes, Does it work on WinXP?
Because I can successfully Ping From Emulator 10.0.2.15 to C4 Mux's IP
Best Regards
PS: I have tested the C4 Mux Workshop mode with above router settings and works on Native/laptop and VMware both connects just fine.
Love your Work!
