  • 10 Vote(s) - 2.5 Average
NISSAN X-TRAIL Denso need DPF off
Hello
Pleaz hellp me with DPF off and EGR off for NISSAN X-TRAIL 2,2DCI FROM 2006 with DENSO ECU sw:t281zr75
ASC won't do this car
THANK'S!!! Handshake
NISSAN_X-TRAIL_DENSO.rar
24
295.3 KB
gxgchiptuning
Hello
here you have dpf off file,you can disconnect all sensor from dpf pipe.
Full WinOLS User
Custom file for TUNE/DPF/SCR/EGR/TVA/VSA/DTC and more...
here she is bro
.zip
Nissan X-trail 2.2 Dci - DPF off + EGR off - sw#T281ZR75.mod.zip
45
312.47 KB
Tuner by day....It seems i don't sleep....
Check my profile for contact info.
Thanks & Rep are appreciated if i helped you in any way!
HI I need help DPF OFF xtrail Denso 2.2 dCI 23710 ES62B 275800-4504.
The car had DPF Emu fitted about 5 years back and it stop working, later found problem - no power supply for EMU which is taken from DFF sensor.
I have tuner for cooperation and we remove from flash, tried different version - every time regeneration start after 70...300km.
Bought another EMU from Poland, ECU fitted with ori SW and EMU installed - the same issue..  regeneration start after 70...300km.
Replace ECU with the same part number after 20km regeneration start.. Sad
Any help appreciated.
x-trail_DPF_OFF.rar
886.21 KB
Welcome Tup Thanks and Handshake reputation.
Thanks given by: uszi69
7 hours ago
02-25-2020, 05:41 PM
02-25-2020, 03:25 PM
02-22-2020, 10:03 PM
02-22-2020, 07:08 AM
