59
Thanks Given: 186
Thanks Received: 141 (42 Posts)
156
42
NTG 2 navigation cannot be activated
Just I bought an ML 320 cdi.year 2008 and burn navi disc 20016/2017 and navi says :navigation cannot be activated.
Any ideas what can I do for run the navi? Thank you
can somebody help me what I can do for run my navi? now I have sw in unit SH3_R9.6.2 i think it was made with V 9 version.
Now I try to use 2010/2011 but with any luck....what dvd I need?
If I helped you.....
need some thanks and reputation
sergdk
Location OfflineJunior Member
Thanks Given: 13
Thanks Received: 17 (7 Posts)
60
22
Hi, I have same issue witn NTG2 with map from 2010. How did you burned dvd? What disc and properties of burning proces?
59
Thanks Given: 186
156
42
(02-02-2017, 10:19 PM)sergdk Wrote: Hi, I have same issue witn NTG2 with map from 2010. How did you burned dvd? What disc and properties of burning proces?
solved: i start with version dvd 2007/2008 v9 than v 12 2010/2011 a than the latest one everything goes perfect
59
Thanks Given: 186
156
42
(02-05-2017, 01:29 AM)sergdk Wrote: (02-03-2017, 12:37 AM)kuba5582 Wrote: (02-02-2017, 10:19 PM)sergdk Wrote: Hi, I have same issue witn NTG2 with map from 2010. How did you burned dvd? What disc and properties of burning proces?
how did you burn a dvd? What kind of dvd?
verbatim dvd-r in some cases try dvd +r slowest speed
