Need Diagnostictool.ini file andregistry settings for Consult 3+ and Tactrix Openport
Hi
i have Tactrix Openport and i want to run with Consult 3+,
I need DiagnosticTool.ini file with Tactrix Openport settings and all modifications of registry if applicable.
in order to run Consult 3+ version  241.20.00
I have tried to set vi_device_name=Tactrix  in DiagnosticTool.ini file
but it did not work
Regards
(02-20-2025, 12:00 PM)kilog Wrote: Hi
but it did not work
Regards
you can only use version 82.50 which supports J2534 API 0.4. newer versions are no longer supported
Thanks given by: kilog
Can you share an active link for such a version please
Also I wonder if that version gives the opportunity for offline programming
Open C:\CONSULT-III_plus\System\Application\ApplicationData\CommonSetting\DiagnosticTool.ini
Search section [device], change it to :
[device]
vi_device_name=OpenPort 2.0 J2534 ISO/CAN/VPW/PWM
Thanks given by: kilog , hoogop
Hi tactrix doesn't support Consult III + after 83.50 .
For newer version you need a VCI with Passthru 5.0 API support (Open Port support only 04.04)
Drive
  • 2007 VW Passat (B6) 3.2 FSI 250hp : MED 9.1 ecu, (10,6° VR6 with direct injection <3) = My lovely daily
  • 2008 Seat Altea XL (5P) 1.9 TDI 105hp (BXE) = (worst 1.9tdi ever still better than 1.6 tdi ! xD)
