Need Diagnostictool.ini file for Consult 3+ and Abrites
Hi
i have Abrites Original and clone and i want to run with Consult 3+,
I need DiagnosticTool.ini file with AVDI Abrites settings and all modifications of registry if applicable.
in order to run Consult 3+ version  241.20.00
I have tried to set vi_device_name=AVDI-PT ABCDEF in DiagnosticTool.ini file
where ABCDEF is the serial number of Abrites interface
but it did not work
Regards
It seems that Abrites doesnt support passthru 05.0 API.
Check your registry
Devices listed only in "KEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\PassThruSupport.04.04\" works only with old Consult II+ (82.5)
Devices listed in "KEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\PassThruSupport.05.00\" might works with latest versions
if you have original one try updating drivers from official website
Drive
  • 2007 VW Passat (B6) 3.2 FSI 250hp : MED 9.1 ecu, (10,6° VR6 with direct injection <3) = My lovely daily
  • 2008 Seat Altea XL (5P) 1.9 TDI 105hp (BXE) = (worst 1.9tdi ever still better than 1.6 tdi ! xD)
