Thanks Given: 20
Thanks Received: 48 (35 Posts)
148
21
Which eeprom can I use as a replacement for a B58253 eeprom? The readout is 512 Bytes. I have an old Audi A3 with EDC15V ECU. Someone already modified the eeprom and write protected the file. I can read and modify the file, but after writing I get a verify fault.
I Do It My Way
Thanks Given: 205
Thanks Received: 24 (20 Posts)
301
135
Try to write as 24c02, done before some days same ecu. If you need eep file I can send it you.
If I helped you, please like and Rep 🙏
Thanks Given: 20
148
21
Thanks mates, bought new 24c02 eeprom, wrote modified file and car is starting.
I Do It My Way
Thanks Given: 20
148
21
My problem was the programmer, did always read 512 bytes but size is really 256 bytes and could not write the modified 512 bytes file. First thought was that eeprom was protected but size was too big. I also have a very simple eeprom programmer ajawe-0812,I selected 25c02 and it read and wrote 256 bytes.
I Do It My Way
