Need Help : Change PIN-VIN Sagem S2PM-382
please someone can help
I need to change PIN + VIN from Sagem S2PM-382
car is Peugeot Partner 1.4 8v
original PIN : DA1U
VIN : VF3GJKFWB95028443
I want to change, to match with used BSI with PIN : B87B VIN : VF32AKFW442210931
the problem is I cannot reprogram the BSI with virgin fiile
maybe different software BSI so, I will try matching with ecu hack PIN n VIN
thanks
Hyundai Hyundai Kia Pin from Vin *FREE* lucky-zg 1,751 171,051 5 hours ago
Last Post: szwajcarek
  Immo off sagem s3000! alfons37 7 309 Yesterday, 01:32 PM
Last Post: Paco230
Citroen Citroen C3 2004 need PIN from VIN _keturi_ 4 144 10-15-2018, 06:20 PM
Last Post: jamalazf
  Need Help for Ford Edge Change Language jcasystems 0 48 10-15-2018, 01:13 PM
Last Post: jcasystems
Renult Renault Sagem S3000 Virgin Tinerfe30 1 69 10-14-2018, 05:57 PM
Last Post: Le-Mans
