Need to know how to R/WR Renault Megane GT Line 2.0 16v 2011
Hi fellow MHH members,
I am looking for some help on a car i want to make tuning for.
Its a Renault Megane GT line 2.0 16v without turbo from 2011 with 140cv.
On kess or ktag/autotuner i cant find the exact same engine with same horespower.
But also on some sites it states there can be 2 types of ecu's on this car.
Siruis 32 and sagem 3000. Both are supported in protocols list in kess.
Can i just go ahead and select the ecu from protocol list and do this car when i am sure what ecu it is ?
Kind Regards!!!!
You at least look at the scanner ID and publish !!!
Thanks given by: Dkaya
(07-09-2019, 09:23 PM)John First Wrote: You at least look at the scanner ID and publish !!!
Thanks for your response.
I am working on the car now as we speak.
Seems like there are 3 types of ecu's used on this engine in diffrent years.
There is a Siemens ems3110, sirius 34 or something and s3000 or something.
After trying to ID and read with all of the protocols. 1 of them worked.
I had to choose the Renault Megane GT 2011 with 250hp. It has the same ecu.
With that protocol i was able to read the car. but not with kess 2.47 it bugs out at 60-80% while reading, and says file transfer failed.
When i use 2.35 it works fine. Now will try to write back.
Have to wait untill the car is cooled off a bit before i can write on this ecu... funny car really.
Will keep u guys up to date about this.
Ok i have written the car with kess 2.25 (not 2.35 as i said before)
Read and write without a hitch. You only need to wait for the engine to be cooled down a bit before you can write your file back.
I have used the Renault Megane 3 GT 2.0 250hp ems3110 protocol.
All worked out great! If you have questions regarding this topic, feel free to contact me anytime!
Kind Regards.
06-12-2026, 07:32 PM
Skoda
06-08-2026, 11:44 AM
05-29-2026, 12:04 AM
