New EZS FBS4 drive authorization failure
Dear members,
An authorized MB garage, has changed EZS in 2013 FL W212 with FBS4. The initialization was done with online Xentry account *ofcourse*.
The ignition turns on, but there is no drive authorization between EZS,VGS,DSM,ECU.
No proficient help could be found via Guided Test of Drive Authorization.
Any help would be much appreciated.
W212 DAS4 ignition switch comes with blue/shop key for drive authorization programming, does it not??
(10-01-2026, 08:10 AM)MBENZTECH Wrote: W212 DAS4 ignition switch comes with blue/shop key for drive authorization programming, does it not??
I have just received an EZS module. And as mentioned the Ignition is working, the car cranked for 0.5 seconds, and than drive authorization errors started to appear.
As a possibility, the 2013 model-year vehicle might use FBS3 authorization.
(10-02-2026, 10:23 AM)ksvsaransk Wrote: As a possibility, the 2013 model-year vehicle might use FBS3 authorization.
The Image I attached clearly states FBS4
Hello, I’m wondering why the EZS was replaced. Was everything working normally before the replacement? Since the EZS was replaced by an authorized dealer, I would take the vehicle back to have them sort it out. Clearly, an error occurred during the initial start-up; the driving authorization was not assigned or was not successfully completed.
(10-03-2026, 12:01 AM)Goku Wrote: Hello, I’m wondering why the EZS was replaced. Was everything working normally before the replacement? Since the EZS was replaced by an authorized dealer, I would take the vehicle back to have them sort it out. Clearly, an error occurred during the initial start-up; the driving authorization was not assigned or was not successfully completed.
New EZS had to be replaced, due to my careless usage of DTS Monaco.
I locked all 8 key tracks (Schiene Sperren). According to WIS & info from this forum (https://mhhauto.com/Thread-FBS4-re-enable-key-track)
Now with new EZS both keys started to work, but the car still wont start
