152
Thanks Given: 17
Thanks Received: 200 (188 Posts)
279
0
04-10-2026, 05:42 PM
(This post was last modified: 04-10-2026, 05:58 PM by WCF_Winols.)
The faults C18F9-02 and C18EA-01 are related to the electric braking system (brake booster / VDC module).
You can perform the following checks:
-Check the 12V battery (stable voltage above 12.5V)
-Check all fuses related to the ABS / braking system
-Verify power supply and ground at the brake booster
-Check the CAN network (continuity and no short circuit)
-Inspect the module connector (corrosion or poor contact)
If everything is OK, then the brake booster is most likely faulty.
[font="Helvetica Neue", Arial]Is your engine code KR15DDT?[/font]
i will help you contact me i send you schema
thx and rep
13
Thanks Given: 181
Thanks Received: 35 (30 Posts)
220
85
04-10-2026, 06:22 PM
(This post was last modified: 04-10-2026, 10:33 PM by ADAM1991.)
I know the procedure for checking these errors. I need a diagram to check the power supply and wire continuity.
