10
Thanks Given: 821
Thanks Received: 80 (62 Posts)
624
251
10-01-2024, 01:35 AM
(This post was last modified: 10-02-2024, 12:50 AM by rasmoka.)
Hello mates, I have fault P0651 that related to 5V feeding
could you please help with full engine diagram?
Installed Global TIS v32 but diagram not shown.
thanks
Edit: For everyone need it, you can install TIS2000 116E and select CORSA D 2011 instead ASTRA J, shematic is same and also checking procedure
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
(10-01-2024, 01:35 AM)rasmoka Wrote: Hello mates, I have fault P0651 that related to 5V feeding
thanks
W0LPE5DH8DG055367
engine A17DTS
Everything you need my friend
10
Thanks Given: 821
624
251
10-01-2024, 02:49 AM
(This post was last modified: 10-01-2024, 02:15 PM by rasmoka.)
Thank you very much friend, I appreciate your help as Opel Diagram is hard to reach
EDIT: the schematic is for 1.3L not for 1.7L. I still need your help please for A17DTS engine
101
Thanks Given: 257
Thanks Received: 399 (91 Posts)
235
53
The schematic should be fine.
If you refer to the DTC P0651, then the Diagnostic should apply to your car as well.
