Hello.....
i have a problem with an easytronic (55564997)
car starts have dtc and F in cluster, the first dtc was for clutch actuator, i make relearn the parameters and replace the brushes and now i have p1735, parameter not learned....
i have make ecu sps to last sw offline update, nothing, i make relearn the values, i can hear the gearbox to work, everything goes well but at the end i still have the p1735....
is this repairable??? or is internal ecu fault????? (i try to read it on becnh with ioterminal but is not possible...)
thanks....
[attachment=622602]
thanks....
[attachment=622602]
