OPEL CORSA E 2016 NOT START AFTER TCM REPLACED
Hello....
i have an Opel Corsa E 2016, in this car have replace the automatic transmission gearbox and now the car doesn’t start.....
in diagnosis i see other win in tcm from that car have...(thats normal...) and i think this is the problem that makes the car to not start.......
tcm info according diagnosis are:
K71 tranmition control module
TCM - T57
MAREL02
43TD1C
Is there any option to start the car???  possible to edit VIN?
thanks....
Need to adapt to car, VIN change not enough
REMOTE PROGRAMMING  Tup
region change, retrofit, add functions, online coding
AUDI, VW, BENTLEY, LAMBORGHINI, PORSCHE, OPEL, GM
with sps online is not possible..... do you know how?
(06-11-2026, 06:17 PM)Chris AGR Wrote: with sps online is not possible.....  do you know how?
Kess, Flex, I/O Terminal or avdi.
ECU-REPAIR-KEYS-IMMO-ABRITES FULL MERCEDES-ALFA-PSA  GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
Every days a schoolday
is possible to read this ecu with kess or ioterminal? can you explain please?
why not possible??
did you try?
if yes post error you get
BTW vin cant make car not start
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
Thanks given by: Chris AGR
Opel
05-30-2026, 08:29 PM
05-10-2026, 11:34 PM
