Hello I need the UHP 4 eeprom file. Anybody can you help me?
[email protected]
OPEL UHP 4 EEPROM
08-25-2023, 06:50 PM
Sps it and it will be clean. No one needs clean eeprom file.
Thanks given by: opelmonster
08-25-2023, 07:46 PM
Thank you. My Uhp 4 module is still paired with its old radio so ı wanted learn because i will pair my cdc 40 opera radio
08-25-2023, 08:18 PM
So why not reset UHP4 by resetting the old radio in the car?
08-25-2023, 09:11 PM
(This post was last modified: 08-25-2023, 09:12 PM by opelmonster.)
Because I bought second hand uhp 4 module
Seller said me uhp 4 module is still paired with its old radio
08-27-2023, 11:43 PM
(This post was last modified: 08-27-2023, 11:43 PM by opelmonster.)
Seller post me the UHP 4 module.
He said me you need to reset
Seller don’t know old code
12-19-2023, 01:11 AM
(08-26-2023, 09:36 PM)plasma533 Wrote:(08-25-2023, 09:11 PM)opelmonster Wrote: Because I bought second hand uhp 4 module
If seller knows old code, can still be cleared
Hello, I bought a new UHP4 Module which already known Security Code.
I tried to program my EHU and DIS with that UHP's Security Code but it says Activation Not Succesful
1- EHU Deactivation Theft Protection
2- UHP Programmed can config-code index-variant as car specs
3- EHU DIS Programmed can config-code index- variant- as car specs
4- EHU Activation Theft Protection and entered UHP's security code and it says Activation Not Successful
Do you know how should I handle with that? Even If I Activate the theft protection and enter the UHP's security code It says still UHP Safe
Note : I can activate theft protection If I program Mid Speed Can Config without UHP and after activation theft protection I re-program the can config to UHP Present and It says UHP Safe.
12-22-2023, 11:47 AM
(12-19-2023, 01:11 AM)opelmonster Wrote:(08-26-2023, 09:36 PM)plasma533 Wrote:(08-25-2023, 09:11 PM)opelmonster Wrote: Because I bought second hand uhp 4 module
Your steps are wrong. Reset UHP with its pin code , and then go to program UHP and enter pin code from your car EHU. Also, variant config and code index for EHU and DIS. If need support - i can help.
