The problem was with ECU module. Changed it and all ok. The problem solved.
p.s. wirings from brake pedal sensor goes to ECU.
Thanks given by: farhadd
(03-14-2017, 04:58 PM)Onotole Wrote: The problem was with ECU module. Changed it and all ok. The problem solved.
