Hello, i have in my garage opel astra j 1.7 cdti 2012 with fault code p1297 fuel pressure regulator not learned/programmed. On car already is changed three fuel pressure regulators and no luck check injectors and everything about fuel line.Car wont stay on idle only if gets very warm can keep a little idle but not stable. I try to adapt fuel pressure regulator with launch autocom delphi wurth original with no luck. Any help?
Opel Astra J 1.7 cdti p1297 help!!
03-03-2023, 06:27 PM
we had the same problem on car like that and kts ,launch,opcom couldnt do it,we did it with delphi 2015 without any problems.
Thanks given by: automated1
05-17-2024, 12:07 AM
I know is an old thread but i a
Runnjng in same problem. To learn the sensor you need. To start the car, mine is not starting and i read 0 bar of pressure. . Mechanically it looks like is at least 100 bar . Very weird. Anybody run i to this kind of problems ?
