Opel Combo 2017 wiring diagram
Hello!
I have a problem with Opel Combo 2017 1,3cdti, airbag light is on and fault code is B00D5 - Restraint System Passenger Disable Indicator
I did try to change the light indicator and still same problem, also changed airbag module and same problem. I think last thing is wire signal loss somewhere, but I need wire diagram of airbag.
Does somebody have wirigin diagram of airbag system to Opel Combo 2017 or I think Fiat Doblo is almost same car?
Thank you
(07-08-2020, 04:13 PM)speed254 Wrote: Hello!
Thank you
hi mate
ı have online account ı can help you
Thanks given by: speed254
speed254 Wrote:Hello!
Thank you
Find the attached it may help you.
Press thanks & rep.
.docx
Airbag Schematic.docx
48
146.8 KB
.docx
DTC B00D5.docx
50
23.33 KB
Thanks given by: speed254 , Stelaras , Orchid70
Thank you all, problem solved.
Broken fuse for indicator airbag due to soft drink spill on ASR button making short circuit, fixed by changing fuse and button ASR.
Thanks given by: Orchid70
Can you help with this issue?At least pin point which fuse??
thanks
If i Helped,please press thanks and +rep buttons
Opel
03-30-2026, 11:29 PM
Opel
03-27-2026, 10:31 PM
