(05-03-2025, 03:58 AM)Jalis812 Wrote: Hi! I have 2001 Corsa C with automatic gearbox. I bought gearbox module and need to code it to match the ECU. It blinks F on dashboard.
I did read of 24c16 on gearbox and of ECU through obd on carprog.
Hello, the letter F usually indicates an error indicating a failure of the clutch actuator or gearbox.
Most often these are worn brushes in the engines.
Best regards
405-03-2025, 04:44 PM (This post was last modified: 05-03-2025, 04:47 PM by Jalis812.)
Best regards
The engine doesnt crank anymore.
(05-03-2025, 01:50 PM)KIR73 Wrote: And the VIN is no sense for easytronic
Then it doesnt make sense why it doesnt crank anymore.
Autel MP900, KESS, KTAG, Super DSP3+, Carprog, Carprog II, PCMflash, Openport, KD-Can
505-03-2025, 04:50 PM (This post was last modified: 05-03-2025, 04:58 PM by sixcode.)
what part number (01329000xx)as your 24c16 is full of garbage
what kind motor code??
but its still used for all units!!
Don't PM me for SW keys, FRM repairs, Licences, radio codes or similar, you will not get any answer...
705-03-2025, 05:42 PM (This post was last modified: 05-03-2025, 05:46 PM by Jalis812.)
its 0132900002. Engine Z12XE. Thanks
(05-03-2025, 05:39 PM)Staker Wrote: If easytronic was from same engine code, then just do clutch calibration and it should be ok.
Otherwise flash it with SPS with cars VIN.
VIN has nothing to do on KLine cars(at least on OPELs), also it is not on immo system.
Do not practise to clone eeproms on these simple cars
So I need to buy SPS online and use openport to program it?
