Matei
Location OfflineJunior Member
Thanks Given: 14
Thanks Received: 1 (1 Posts)
46
25
Check instrument cluster pins, fold a piece of paper under the connector and reseat it.
1,189
Thanks Given: 2970
Thanks Received: 5301 (3065 Posts)
9,209
425
read pin from all ..reset and match again ..it will start
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
(05-28-2024, 04:26 AM)autoepopovic Wrote: (05-25-2024, 11:46 AM)delimemet Wrote: read pin from all ..reset and match again ..it will start
I did everything as you said, I also replaced the odometer. But car again don't start.
any other ideas? Thank you very much for reply and help!
If you still got problem you can contact me on Skype. I will help you to solve this.
I can provide wiring diagrams, parts number, technical service bulletins, part replacement procedures etc.. for Citroen/Opel. No pin code or key cut codes.
